danm,im computer stupid(maft an Atap
*Bad Trader*
.. i still dont know what im looking at on atap, i want to set my maft up right, i monitor o2 volts, engine speed(rpm)s-trims and l-trims,fuel cell,kr, timimg... what do i need to get them too, how do i get the data i need , btw my afr says 14.6-1 is this possibly right?? im noew to the computer aspect so go easy on me
Re: danm,im computer stupid(maft an Atap
Hey Grinch, you answered my nitrous questions a couple of daya ago, so here is my attempt at answering yours.
I have used this site as a reference to setting up autotap. It has an autotap config file to load that will pick all of the important measurements and comes with an Excel template that will give you your needed averages.
http://www.c5forum.com/diy/ltft.php
Take a look and let me know if you still need some help.
Richard
[ December 27, 2001: Message edited by: BigTex ]</p>
Richard
*Bad Trader*
for some reason i cant open that.
what do i need to monitor? and how do i get it where it needs to be? are u gonna be out this weekend maybe u can help me in trad for some n20 help. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
[quote]Originally posted by Grinch(supra killa):
<strong>.. i still dont know what im looking at on atap, i want to set my maft up right, i monitor o2 volts, engine speed(rpm)s-trims and l-trims,fuel cell,kr, timimg... what do i need to get them too, how do i get the data i need , btw my afr says 14.6-1 is this possibly right?? im noew to the computer aspect so go easy on me</strong><hr></blockquote>
You want:
*o2s in the .880-.890 range n/a and .890-.900 on the juice.
*Ltrims in the single digits...preferably negative.
*timing up around 28-30.5 with a stock motor n/a...preferably lower with the juice (26-28).
*Knock retard at 0.
Use the base dail on the MAFT to dial in your Ltrims to single digits. Use the WOT dial to get your o2s in the ranges I gave you.
I know this is a very basic explaination. I have a lot more information and links saved on my computer in Athens, but I am in Albany right now. I will post the links and info in this thread when I get back up to school on the 30th.
Chris G
[ December 27, 2001: Message edited by: Chris G ]</p>
You want:
*Knock retard at 0.
Chris G
Chris G and BigTex got it.
Go to http://www.c5forum.com/diy/ltft.php
Read it and do what it says. If you still need more info, you didn't actually read it.
Dope
Dope
