Found a bug on '98 LS1-EDIT Someone let Ken know that I couldn't change my tire height value on the '98 LS1-EDIT. Whatever I typed in the box went back to 25.62" when I tried to save it. Tony |
Re: Found a bug on '98 LS1-EDIT OK, I tried it on a 99-00, and it worked. I then tried it on a 98, and I can repeat your problem. I will fix it. Ken |
Re: Found a bug on '98 LS1-EDIT Thanks Ken, and welcome to the site! Hope you visit as often as you can <img src="gr_grin.gif" border="0"> Tony |
Re: Found a bug on '98 LS1-EDIT I've noticed that the first opened filename does not display in the various table views. Opening a second file to compare with does display the second file name. Also the graph views do not include the x axis values. Plus I've gotten some MILs after just reading the PCM parameters. I've see a P1518 and a P1134 (this may be a quirk). I had to clear them with an autotap. It would be nice if ls1prog could clear them. |
© 2024 MH Sub I, LLC dba Internet Brands
