LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Can't get rid of the SES light , help (https://ls1tech.com/forums/pcm-diagnostics-tuning/42867-cant-get-rid-ses-light-help.html)
BigD'sZ May 9, 2002 05:29 PM
I've tried pulling the PCM BAT and PCM IGN fuses with the key in but not on, no luck. One thread I read said the key had to be on, but a Haynes Manual I have says if I do that it will crash the computer. Help.
Nine Ball May 10, 2002 08:56 AM
Re: Can't get rid of the SES light , help
It might help if you get Autotap to at least find out what the SES code is. Then we might be able to help you fix the issue that causes the light.
Tony
dfarmercse May 10, 2002 09:16 AM
I had a ses light the other day and I turned on my key and pulled the fuses. I did not crash the pcm and my ses light has not come back on. I have driven about 200 miles and it seems to be running well. 99 T/A WS6
Toxic Texan May 10, 2002 11:25 PM
Look you get codes for a reason. Find out the reason before you clear it. Go to autozone they will scan your car and tell you the code for free. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
© 2026 MH Sub I, LLC dba Internet Brands
