Oxygen sensor malfunction?
Old Dec 30, 2005 | 04:50 PM
transam69230's Avatar
Default Oxygen sensor malfunction?
Does this mean that the sensor is bad? I just replaced both of my sensor this summer when i got my header install, and today i went to start it up in my garage cuase it hasn't been started in a while and i get a DT. When spring comes i can just drive it and then it will start the cycle over and be corrected or do i have to buy a new sensor again? I cleared the code with the diablo that i have for my car. I don't want a to buy another sensor what can i do?
Old Dec 30, 2005 | 08:16 PM
Bill Bowling's Avatar
Talking
What code did you get?
Bill
Old Dec 30, 2005 | 08:35 PM
foff667's Avatar
LS1TECH Sponsor
Bill
Old Dec 30, 2005 | 09:13 PM
po135
Old Dec 31, 2005 | 03:24 AM
98A4LS1's Avatar
DTC P0135 - HO2S - Heater Performance Bank 1 (left) Sensor 1 (front)
PCM runs the heater test on cold start and only once on ignition cycle. When you start the engine the PCM monitors O2 voltage. When O2 voltage goes above or below bias range threshold, the PCM determines how much time it took. If the PCM determines it took to long DTC is set.
