F14 in have a few Questions..SES lights
Yep! Finally have the F14 in with all the goodies. Well, heres the questions:
1st: When I start the car it idles fine, but as soon as I put in gear, the ASR light comes on meaning the Traction Control is turned off. Why? Anyone ever here of this??
2nd: Thrown a TPS-range/perf code about 8 times today since I got the car running. Never heard of that before. Why?
But of course, I have all the usual stuff associated with big cams in a4 cars..random misfire codes, surging while in gear at a stoplight(which is quite interesting I must say), people looking at you strangly because my Camaro 'surges' at stoplights and its cammin pretty hard. It needs a tune bad, can hear some knock at moderate throttle going down the street..but my y-pipe is banging again which has a bit to do with it I think.
Ski
Ski
yea, i reset the tps sensor. but it still throws the code everynow and then. I'm just writing it off as the effects of a large cam in a a4. I'm cool with it for now. It'll get fixed when the car gets tuned.
Thanks all for the help.
Ski
Ski
Originally Posted by NicD
Those codes are normal for an untuned car. It does not mean you have a bad sensor and has nothing to do with setting the TPS. It just needs to be tuned.
7 Second Club
Originally Posted by 99whitews6
Correct, the codes are normal for an untuned car, But, the TPS sensor does need to be reset if the set screw has been adjusted. I just thought this may be the code that he was throwing!
