PAGING KEN from Carputing...
Old May 31, 2002 | 04:03 AM
02BlackWS6's Avatar
Default PAGING KEN from Carputing...
Ken,
I'm still having trouble getting my Vig3600 converter to lockup. You emailed me and asked me if i had any codes stored in the pcm. Which i don't. I was also told to raise the Max. and Min. misfire temps. Which i did. I also disabled all the Misfire codes using EDIT. I'm still not seeing my converter locking up. What else can i try? Is there any other codes i need to disable? Or do i need to lower the MPH in the TCC section to get it to lockup? I can really use some help here. FWIW, I have a TR224 112lsa cam and S2 heads with FLP's. With my custom tuning (which i had done before i learned more about LS1 EDIT) the torque converter locks up at the stock MPH's. But since that tuning is locked i want to create my own custom file. Which is why i bought EDIT in the first place.
Thanks,
Den
Old May 31, 2002 | 08:58 PM
nevrenuf's Avatar
Default Re: PAGING KEN from Carputing...
You may have better luck contacting Ken directly. He is VERY good about answering emails...
pcmdoc@surfree.com
