LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Won't start with SD tune (https://ls1tech.com/forums/pcm-diagnostics-tuning/433814-wont-start-sd-tune.html)
BLUE99T/A Jan 8, 2006 09:55 PM
I have the idle tuned pretty good. Now I'm tuning VE, but after I load the SD tune, the car needs pedal to get started. Is this normal? Will this iron out once VE is closer?
It does this at all temps.
BLUE99T/A Jan 9, 2006 07:43 PM
Come on tuner guru's. Did anyone have to make idle adjustments after disconnecting the maf?
Bink Jan 9, 2006 07:52 PM
Try scaling your Cranking VE by the same %s of your SD VE table.
© 2026 MH Sub I, LLC dba Internet Brands
