LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   What's wrong with drilling the TB? (https://ls1tech.com/forums/pcm-diagnostics-tuning/433942-whats-wrong-drilling-tb.html)
Zeus Jan 9, 2006 05:47 AM
I'm trying to fine tune my idle right now, and with my big ass cam, I've already maxed out the TB set screw. I removed it and reinserted it from the top allowing on-car adjustments, so it's not that I've maxed out the range of the screw. The problem is I've maxed out the range my TPS can compensate for.
I think I reached the maximum threshold of recalibration because now it won't recalibrate back to 0% anymore. My IAC counts are still in the 150 range even with the car fully warmed up. My question is, what is wrong with drilling the TB blade? Is it bad because it leaves no room for adjustment after it's done, or is it because it has bad properties in terms of a fluid dynamcs perspective?
I was thinking of enlarging the hole a little just to bring everything back into the range of adjusting via the setscrew. Is this a bad idea? I don't want to disassemble the TPS and realign it with the shaft unless I really have to.
MNR-0 Jan 9, 2006 06:37 AM
In your case, there is nothing wrong with drilling the TB hole. Sounds like you need mucho air in there. The factory specifications will stretch only so far.
jimmyblue Jan 9, 2006 06:50 AM
It's just the difficulty of undrilling it, that makes it
something to do only after tuning fails (not as a
shade tree substitute for it).
Nick Williams Jan 9, 2006 08:13 AM
Drill it if you want. There is nothing wrong with doing it. Just go up in size slowly so you don't go too big.
Nick
ringram Jan 9, 2006 09:24 AM
You can losen and slightly elongate the TPS sensor mount on the side of the TB and twist it to get more movement, might help if you are close.
© 2026 MH Sub I, LLC dba Internet Brands
