LTFT'S at 25%. How to lower with edit??
mine where +23 and i mult the table by like 117, then came back and mult the cells almost all the way over by 104(then the next cell i dowscaled going to 103, then next cell to 102, then 101.. then stopped).. btw, if you do that make sure you click the mult selected cells only grid)
but i think my car didnt like mult the whole maf by such high numbers, so 110-115 would be the the max i would go...
this is also another format i did ona friends car and it worked(from someone off of here)
"I was running between 15% to 20% for the Ltrim fuel on my '99 SS.
I'm assuming that you have LS1_Edit.
With LS1_Edit, I would do the following changes to the MAF table:
1500Hz to 6000Hz: multiply by 120%
6125Hz: multiply by 119%
6250Hz: multiply by 118%
6375Hz: multiply by 117%
and so forth until you multiply by 101%, then stop
Flash this new program back onto your PCM.
This technique reduced my Ltrims down to a range from -5% to 0%.
Do a PCM reset and go out and drive the car around for about 15 minutes then do some ATAPing."
While I am driving...what should they(LTFT) be reading?
<small>[ September 29, 2002, 01:27 PM: Message edited by: superchargedZ ]</small>
log your LTRIMS while cruising around for 10mins or so.. then average them. Thats what you will need to go by when mult the MAF table <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
but you have the hang of it so you know what to do now. Just work your way accordingly and see how it goes
Thanks Jason
<small>[ September 29, 2002, 12:44 PM: Message edited by: superchargedZ ]</small>
