do any of the stock gauges run without the VCM/whole computer?
7 Second Club
just wondering if i can still use all the gauges (factory), radio and heat with out the computer/VCM in the car.
thanks,
Tyler
thanks,
Tyler
not sure about heat/radio, but most of the gauges will not work w/out the PCM....
That's why AFtermarket solutions like Big Stuff 3 have gotten popular... BS3 provides provisions to interface w/your stock gauges.
But... I think only the oil pressure gauge will work w/out hte stock PCM or an aftermarket computer capable of controlling the gauges.
The Radio will likely work as I don't think the PCM has nything to do with it... but I'm not sure about heat/AC
7 Second Club
what about the fuel gauge?
are you positive about oil pressure?
fuel gauge wouldn't work since the info goes to the PCM then to the Gauge Cluster
I'm not 100% positive on oil pressure... however I know on F-Bodies the feed for oil pressure doesn't go to the PCM, it's a direct feed from the sensor to the the gauge cluster (Y-Body's have the feed going to the PCM, hence why you can't log Oil pressure on F-Body's)
However since I have never tested the above personally (checking oil pressure w/out a PCM) I can't be 100% certain
What provisions did BS3 come out with to work the stock guages?
I have only gottent he volt, gas level, oil press, and water temp to work since changing to the BS3. Anyone know how to get the tach/ obdometer and speedo to work let me know. The car is an auto trans.
