WTF! LS1 edit won't connect? i just finished down loading a program to my pcm and i recet the pcm. i tried to fix something else with edit 1/2 hour later and it keeps trying to " re-establish connection with the pcm"??? it keeps cycling that message with no results. i checked all the connectors and i also ran the EASE scanner just to make sure i don't have a problem with the under dash port and it worked , but the EDIT didn't?? and now my oil guage needle keeps twiching?? what is going on?? all the lights on the connector thingy are working ( except the second one from the left). |
Re: WTF! LS1 edit won't connect? Yank both fuses to the PCM for about 30 minutes, sounds like PCM was left in a weird state. |
Re: WTF! LS1 edit won't connect? thanks john , i'll try that right away. |
Re: WTF! LS1 edit won't connect? i disconected the fuse and reconnected it 30 min lar=ter and that seemed to work. then i tried to edit again and the same problem came back!! is there something wrong with the software? well atleast the oil guage twitching stoped. |
Re: WTF! LS1 edit won't connect? Do you have an InfraRed port on your laptop? I had to disable mine to get edit to connect. My laptop would connect one time and then not connect 2 minutes later. My laptop kept confusing the IR com port and the edit com port. Make sure edit is trying the correct com port. <small>[ December 13, 2002, 01:36 PM: Message edited by: red53gmc ]</small> |
Re: WTF! LS1 edit won't connect? it does have it , but why would it suddenly decide to connect using the infra raed port?? how do you make sure edit is not using the wrong port? |
Re: WTF! LS1 edit won't connect? CRAP! i tried to connect again and it did , but it disconnected half way through the down load! car won't start now, what should i do?? man i'm so pissed off. |
Re: WTF! LS1 edit won't connect? I have that happen on a pc die half way through a download and car wont start. Downloaded fully again and car starts. |
Re: WTF! LS1 edit won't connect? thanks strife, i hope that's the case with my car. my initial problem is the ls1 edit won't connect!! if i could get it to connect i would be so happy! nothing has been going right lately. any ideas ?? |
Re: WTF! LS1 edit won't connect? I find that I have about a 50% chance of LS1_Edit connecting on the 1st try <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> I have no idea why this is. What I typically do is disconnect the cable at the ADL connector and reconnect it and try again. If this doesn't work then I close the program completely and try again. Usually on of these two procedures works. I firmly believe the software has a bug in it which causes this <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> |
Re: WTF! LS1 edit won't connect? i tried that several times , but it didn't help. the weird thing is it never did this before! |
Re: WTF! LS1 edit won't connect? </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1dirtyZ: <strong>i tried that several times , but it didn't help. the weird thing is it never did this before!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Look at what day and date it is. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> John |
Re: WTF! LS1 edit won't connect? man , i'm not superstsious (sp?) at all, but it has been strange lately. my PC froze 4 times , my tv remote is on the blink ( some buttons work and some don't), my VCR won't record, my car's pcm is fried, my trucks radiator cap was off and the radiator was 1/2 empty. what else can i say <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> |
Re: WTF! LS1 edit won't connect? If there's a bug in the upload/download software, I have yet to find it. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Never had a problem here, across multiple vehicles. Anyhow, I tend to believe that your problem is being caused by something on the laptop. An infrared port can cause what you are seeing - it can connect, and then cause a disruption in communications partway through the download. I have been down that road myself. Disable the infrared port in the BIOS, make sure there are no drivers loaded on the laptop (Palm Hotsync, serial mouse, GPS interface, etc). Good luck. Andrew |
Re: WTF! LS1 edit won't connect? already did that , no go... the laptop is dedicated to the car , so no other softwear is on it, plus none has been added for ages now. <small>[ December 13, 2002, 11:41 PM: Message edited by: 1dirtyZ ]</small> |
Re: WTF! LS1 edit won't connect? ditto on the laptop. The newer laptops seem to have this problem. I think it is related to the operating system. Anyhoo, I use Win95 with a Com port and have NEVER had a problem connecting with my personal. However, our new fangled laptop with every bell and whistle at the shop I have problems connecting with all the time. |
Re: WTF! LS1 edit won't connect? i don't think it's the lap top, first cause it's been working flawlessly for a year. and second is cause i went to a tuner shop here and tried their cable and laptop. so far ken at carputing has been very helpfull , i'm just waiting for a reply on monday. |
Re: WTF! LS1 edit won't connect? well i have been having trouble with a friends car, we just disabled his infra red port and we will just have to see if it works now... |
Re: WTF! LS1 edit won't connect? Im scared of LS1 EDIT now. I just hope ur PCM is fine man. So u guys mean that Win XP isnt compatable with LS1 Edit?? |
Re: WTF! LS1 edit won't connect? no issues with xp and w2k on mine with com port, never any connect issues. just do all the steps nice and carefully etc |
| All times are GMT -5. The time now is 04:09 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
