idle question and iac's with ls1edit...
Old Dec 16, 2002 | 11:10 PM
1badvr4's Avatar
Default idle question and iac's with ls1edit...
ok, if the car is running too rich at idle, im supposed to drill a bigger hole in the throttle body and lower the idle from the pcm with edit right? what is a good range of iacs for idle? thanks!
Old Dec 17, 2002 | 09:17 PM
NoGo's Avatar
Default Re: idle question and iac's with ls1edit...
On a manual car IAC between 30 and 50 work good.
On an automatic car IAC between 60 and 90 do the trick.
Good Luck,
Kevin
Old Dec 18, 2002 | 06:52 AM
Tom99SS's Avatar
Kevin,
Are those IAC counts for when car is in park or in gear for an automatic?
Thanks,
Tom
Old Dec 18, 2002 | 07:03 AM
NoGo's Avatar
Those are in park.
In drive, or with the engine under some form of load (ie AC), I try to get them to 100-110.
