7.0 liter tuners inside please..
Just make sure that your injector flow settings are correct for your 42 lb injectors.
Additionally, make sure you raise your idle a bit to accomodate your larger cam as well as increase the idle air and IAC in park position tables accordingly.
And setting the cubic inches correctly will help with tuning WOT runs on the dyno.
Good Luck,
Kevin
