What's the best A/F on a dyno?
Old Apr 14, 2003 | 08:30 PM
Vettepartz's Avatar
Default What's the best A/F on a dyno?
I have seen this mentioned before, but can't find it now. What is the best A/F for max performance when measured on a dyno, not on the street. I believe there is a value at max torque and at max horsepower.
Old Apr 14, 2003 | 10:13 PM
WS6 GreeN's Avatar
Default Re: What's the best A/F on a dyno?
You should shoot for a 13:1 A/F. I've heard though that you go 12.8:1 because on the track it actually runs a little leaner. Mine's at 13:1 and makes max hp. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 14, 2003 | 11:17 PM
CMNTMXR57's Avatar
Other way around. 12.8:1 would be richer. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
12.8 parts of air to one part fuel.
Anywhere between 12.8 - 13.1 is optimum. I say that window cause each cars is slightly different.
Old Apr 15, 2003 | 09:38 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
On a Dynojet...
I'd say:
12:1 AF for forced induction
12:1 - 12.5 for stroker
12.5-12.8:1 for stock cube NA
Old Apr 16, 2003 | 12:38 AM
TaTommyWS6's Avatar
My understanding is for a NA car:
12.5-12.8 near peak torque
13.1 near peak hp
Tommy <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 16, 2003 | 02:22 PM
Vettepartz's Avatar
OK, for calculation purposes, let's ASSUME that 12.8 is for max torque and 13.1 is for max HP. Should the fuel curve at WOT be mostly at 13.1 and dip to 12.8 at max torque rpm, or be at 12.8 and rise to 13.1 at max hp? Or maybe run somewhere in between?
Old Apr 16, 2003 | 03:33 PM
killer01ws6's Avatar
each of our cars likes things a little diffent, mostly becasue of air quality, +/- sea level
etc. BUT you are right on for the base line. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Apr 16, 2003 | 06:54 PM
WS6 GreeN's Avatar
At 13.2:1 I made 4 more ft/lbs of torque than I did at 13:1 HP stayed the same.
