MAF calibration differences I've noticed.... My Z06 was orginally tuned a few years ago using edit for the cam only setup. I have now installed a set of PRC ported Ls6 heads. I LOVE EFILIVE so far I obtained a stock Z06 .bin file from Horists site and used the compare feature to see what had actually been changed on my car. Im a newbie, but Im under the impression that the Maf table should not be changed since the MAF sensor is stock, below are the differences Ive found. The car appears to be running on the rich side. Should I copy the table back to the stock settings? Any comments appreciated. The PE modifier based on RPM appears stock on my car.... Let the village idiot questions begin! :jest: My 2001 Z06 Maf LABELS MAF Sensor Calibration (Lbs/Minute) Hz {link: GM.MAFFREQ} Value 1500 0.270754 1625 0.330693 1750 0.38753 1875 0.454702 2000 0.529108 2125 0.609714 2250 0.695488 2375 0.794695 2500 0.898037 2625 1.012746 2750 1.137789 2875 1.271099 3000 1.41371 3125 1.568723 3250 1.729935 3375 1.900449 3500 2.084396 3625 2.280745 3750 2.490528 3875 2.719946 4000 2.966932 4125 3.094042 4250 3.217018 4375 3.49914 4500 3.790563 4625 4.085086 4750 4.399244 4875 4.729936 5000 5.075097 5125 5.436792 5250 5.816055 5375 6.220119 5500 6.641752 5625 7.094388 5750 7.569758 5875 8.073031 6000 8.599039 6125 9.151915 6250 9.727527 6375 10.330007 6500 10.956256 6625 11.606274 6750 12.284193 6875 12.987948 7000 13.718572 7125 14.470898 7250 15.251125 7375 16.061322 7500 16.897354 7625 16.918022 7750 16.961426 7875 17.115404 8000 17.947303 8125 18.804003 8250 19.686539 8375 20.592843 8500 21.515682 8625 22.467456 8750 23.447133 8875 24.456778 9000 25.495359 9125 26.56701 9250 27.678963 9375 28.840521 9500 30.022746 9625 31.254576 9750 32.522575 9875 33.832944 10000 35.186717 10125 36.570458 10250 37.995536 10375 39.459884 10500 40.963502 10625 42.508456 10750 44.09578 10875 45.725474 11000 47.394437 11125 49.108871 11250 50.866709 11375 52.666916 11500 54.51156 11625 56.400641 11750 58.335193 11875 60.315214 12000 62.343806 Here is the supposedly stock values from a .bin on Horists site (2001 Z06) LABELS MAF Sensor Calibration (Lbs/Minute) Hz {link: GM.MAFFREQ} Value 1500 0.195315 1625 0.237685 1750 0.281089 1875 0.329659 2000 0.382363 2125 0.440234 2250 0.503273 2375 0.573545 2500 0.648984 2625 0.732691 2750 0.822598 2875 0.918705 3000 1.022047 3125 1.132622 3250 1.250431 3375 1.373407 3500 1.504651 3625 1.646229 3750 1.799174 3875 1.96452 4000 2.144334 4125 2.341716 4250 2.555633 4375 2.779884 4500 3.012402 4625 3.245954 4750 3.49604 4875 3.758527 5000 4.033415 5125 4.320704 5250 4.623495 5375 4.941786 5500 5.277646 5625 5.637274 5750 6.016537 5875 6.415435 6000 6.833967 6125 7.272135 6250 7.729937 6375 8.208408 6500 8.706514 6625 9.224254 6750 9.762663 6875 10.32174 7000 10.900452 7125 11.499832 7250 12.120914 7375 12.763698 7500 13.427149 7625 14.115403 7750 14.827426 7875 15.560116 8000 16.316575 8125 17.095769 8250 17.896665 8375 18.72133 8500 19.559429 8625 20.42543 8750 21.316233 8875 22.232871 9000 23.177411 9125 24.150888 9250 25.1626 9375 26.218749 9500 27.294533 9625 28.412687 9750 29.567011 9875 30.757504 10000 31.9883 10125 33.246998 10250 34.541866 10375 35.87187 10500 37.240111 10625 38.64452 10750 40.087166 10875 41.568049 11000 43.087167 11125 44.644523 11250 46.242181 11375 47.879109 11500 49.55634 11625 51.273874 11750 53.032745 11875 54.832952 12000 56.675529 |
1 Attachment(s) Here is my recent dyno with the new heads. As you can see it appears I have a few issues. I have an Lc1 which I plan to hook up in the stock O2 location this week... |
The MAF table will need to be recalibrated after you get the VE table dialed in. More then likely they just adjusted the MAF table only to compensate for the fueling as well as possibly the IFR table. |
Originally Posted by Black02SS The MAF table will need to be recalibrated after you get the VE table dialed in. More then likely they just adjusted the MAF table only to compensate for the fueling as well as possibly the IFR table. LABELS Injector Flow Rate (Lbs/Hour) Manifold Vacuum inHg Value 0.0 40.179140 1.5 40.551169 3.0 40.737184 4.4 40.923198 5.9 41.295227 7.4 41.419237 8.9 41.605252 10.3 41.977281 11.8 42.163295 13.3 42.473320 14.8 42.721339 16.2 42.845349 17.7 43.155373 19.2 43.341387 20.7 43.589407 22.1 43.837426 23.6 44.023441 |
Looks to me like the IFR is set unrealistically high (for a lean result) and the MAF is also raised up (for a rich result; perhaps to compensate IFR - or vice versa). The Z06, descreened MAF, can be perturbed some by the intake tract hardware but I'd step back to (1) a believed-proper IFR table, based on what you know about delivered fuel pressure as sqrt([FP+vac]/40)*30lb/hr and try putting the MAF table to whatever matches the MAF hardware you've got (descreened Z06, screened truck, whatever this 2001 has going). Yesterday's high fashion is today's fashion mistake.... |
Ok this is what I come up with for the IFR using red supras calc for 30/lb SVO injectors @ 40psi converted to our 58psi.... ??? I think this looks much closer... Enter your values here: Injector Rated Fuel Pressure: 40 psi Your Fuel Rail Pressure: 58 psi Injector Rated Flow Rate 30 lb/hr New Injector Flow Values MAP (PSI) MAP (kPa) G/SEC LB/HR LB/MIN 0.0000 0 4.5517 36.1254 0.6021 0.7252 5 4.5801 36.3506 0.6058 1.4504 10 4.6083 36.5743 0.6096 2.1756 15 4.6363 36.7967 0.6133 2.9008 20 4.6642 37.0178 0.6170 3.6260 25 4.6918 37.2375 0.6206 4.3512 30 4.7194 37.4560 0.6243 5.0764 35 4.7467 37.6732 0.6279 5.8016 40 4.7739 37.8891 0.6315 6.5268 45 4.8010 38.1039 0.6351 7.2520 50 4.8279 38.3174 0.6386 7.9772 55 4.8547 38.5297 0.6422 8.7024 60 4.8813 38.7409 0.6457 9.4276 65 4.9077 38.9509 0.6492 10.1528 70 4.9341 39.1598 0.6527 10.8780 75 4.9602 39.3676 0.6561 11.6032 80 4.9863 39.5743 0.6596 |
Originally Posted by jimmyblue Looks to me like the IFR is set unrealistically high (for a lean result) and the MAF is also raised up (for a rich result; perhaps to compensate IFR - or vice versa). The Z06, descreened MAF, can be perturbed some by the intake tract hardware but I'd step back to (1) a believed-proper IFR table, based on what you know about delivered fuel pressure as sqrt([FP+vac]/40)*30lb/hr and try putting the MAF table to whatever matches the MAF hardware you've got (descreened Z06, screened truck, whatever this 2001 has going). Yesterday's high fashion is today's fashion mistake.... Thanks. I'll really be set when I get the LC-1 installed. ;) I know the car is running rich now though my narrowbands are reading .950's to .980's at WOT. |
| All times are GMT -5. The time now is 08:31 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
