LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   when do stit's take over coming to a stop? (https://ls1tech.com/forums/pcm-diagnostics-tuning/482841-when-do-stits-take-over-coming-stop.html)
P Mack Apr 5, 2006 12:01 AM
At what point do the stit's become active and start trying to keep the rpm at idle speed when rolling to a stop? Is it when you get under your throttle cracker disable speed?
TAQuickness Apr 5, 2006 04:15 AM
These are all stock settings:
I believe it occurs when the TPS is <= 0%, RPM <= 1200, ECT > 80* C, Engine speed is in error by more than 60 RPM for more than 1.3 seconds.
P Mack Apr 5, 2006 06:33 AM
Just to be clear, i'm talking about the IAC reacting to get rpms back to idle rpm, i'm not talking about the conditions for ltit to learn. So you're saying it doesn't matter if the car is still moving at 10 mph?
98Z28CobraKiller Apr 5, 2006 07:56 PM
The IAC starts working at 0% throttle position. Doesn't matter if you are rolling at 50 mph. Think about it, if not, the car would die once you let off the gas (unless you have a really big hole in the butterfly or you have the screw turned in and the throttle is cracked open at 0%).
P Mack Apr 5, 2006 08:27 PM
Mine doesn't seem to be working that way. It'll let the rpms drop below idle when i'm still rolling and the iac doesn't even react. I don't see how the iac can be adjusting to get back to idle rpm while the throttle cracker is messing with the airflow values.
TAQuickness Apr 5, 2006 08:36 PM
Negatory ghost rider... IAC starts working before you start the engine, and continues until you shut her down.
P-Mack - I had a very similar problem. I had to adjust the follower decay rate to make a nice gentle transistion back to idle. If your car is rolling at 10 mph, the cracker may still have an effect on the IAC. Stock settings on the cracker are to deactivate around 1 or 2 mph. I believe both cracker and follower must be deactive or fully decayed before the PCM will transition back to an idle state.
TAQuickness Apr 5, 2006 08:38 PM
One more note, I found it helps to monitor the IAC stuff in the chart/trend displays. Makes a much better visual for what may be an influence.
P Mack Apr 5, 2006 08:38 PM
Hmm, that's the info i'm looking for. Can anyone else back this up?
P Mack Apr 5, 2006 10:38 PM
I just went out and did some scanning. Looks like throttle position doesn't have to be 0% for the stit's to adjust. And from what I can tell, speed must be <= throttle cracker disable speed for the stit's to move.
TAQuickness Apr 6, 2006 04:42 AM
I can confirm the STIT is not restricted to standing short term idle trim.
© 2026 MH Sub I, LLC dba Internet Brands
