raf tuning
raf tuning
ok, so I'm wondering if I'm doing this right. last night I messed with the set screw on my throttle body to get my IAC counts to 50, give or take a couple, at warm idle for my new TSP 228r cam. the tuning document said to go for 40-60 so I figured I'd split it. so I next went for the base running airflow table and logged ETC, STIT, and both LTIT parameters to use Marcin's spreadsheet. my LTIT parameter (technically the only one in use since I have an M6) read -.040 during the entire warmup process and idle at running temperature, which I thought was odd. it also didn't want to idle at 930 where I had it set, but more like 1030. I went ahead and used the spreadsheet anyway and it created a new table pulling some air out of a couple cells, as I expected it would. I proceeded to start the car and after some feathering of the throttle it found its idle and I did some more logging. my LTIT still sat at -.040 and my idle was still about 100 higher than commanded. my IAC, however, jumped to 74 or so, apparently compensating for the lower raf values. my question is is this supposed to happen? it doesn't seem right with the static LTIT value and the IAC jumping up after the table edit. am I following the steps to get the table right correctly? oh I also might add that my passenger side seems to be dumping fuel since my LTFT on that side is running 25% for what reason I do not know... any thoughts or suggestions from anyone? thanks.
yeah looking forward to that...replacing the bosch 13111 i bought 9 months ago
wouldn't know what to do if I could go a month without something breaking on this damn thing....
does everything else sound right though? is the IAC supposed to move when the RAF is adjusted? it would almost make sense if it does, but if so, what is the point of using the set screw to adjust the blade in the first place?
I don't see how RAF will ever get nailed down if the IAC keeps moving off the 50-count target...
and yet another reply to my own post....
does anyone the relationship between SD mode and the RAF table as in:
1) can the RAF table be tuned while in OLSD?
I'm about ready to say f*ck the o2's and this fuel trim problem for awhile and just run in SD mode...can I get a working raf table in that mode?
2) is the RAF table used in OLSD?
basically, if I get a working RAF table, will it do me any good running in this mode?
any answers will be greatly appreciated.........
Originally Posted by luv2spd
There are other possible causes for the high ltfts. I'd check for intake leaks to start.
btw, do you go to ksu??
Yes, I did go to KSU but graduated last December.
Originally Posted by white2001s10
I'm going to say yes on both counts.
I prefer not to have the fuel learning routine working when trying to sort something out.
Are you running the stock Maf or aftermarket? I triied a 2004 zo6 maf and SLP and both would not let my car go into open loop and my stf's would bounce back and forth to 25%, put the stock 74mm maf back in a worked perfect.
When starting tuning you are MUCH better off in open loop speed density. O2 and MAF will just mess things up. Start at the begining and work through. Enable MAF and O2 once the rest is sorted out. You will want to get your idle area VE sorted out in OL SD mode as every cold start will put you there anyway. O2 feedback doesnt come into it until ECT gets to 50*C.
I am all but ruling out a MAF problem at this point since the fuel trim problem is not symmetrical...the 25% problem exists in only bank 2. bank 1 is fine.
