LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Crank position sensor Missing higher RPM's (https://ls1tech.com/forums/pcm-diagnostics-tuning/515529-crank-position-sensor-missing-higher-rpms.html)
NXZ28 May 28, 2006 01:55 PM
Replace the crank sensor now it at least runs, but starts stumbleing at 4000 and up. Then I will loose the tack and stall It fires right back up. Did the relearn on it any sugestions.
© 2026 MH Sub I, LLC dba Internet Brands
