8.1 -- Anyone Tuned With HPTuners?
I can tell they are very detuned. As far as time I'm not sure. I have ls1edit for my truck. I was having false knock problem, when I did get some knock the Mahle piston I was using cracked.
What little I can remember is. The Hyperjoke added 4deg to the low and high oct tables. If I remember right I added 6deg more to both. I was having false knock problem at idle and low throttle at wot no problem. The knock problem I did encountered came bad gas and a 200hp shot of N2O.
BTW this is with aluminum heads.
