Dtc's After Rtt Upgrade In Hpt
After I Upgraded My Bin File To A "maf Rtt" Enhanced Os I Throw 4 Or 5 Dtcs That Wont Clear ... They All Start With U And Are Numbers Like "u1000 Loss Of Communication With Xxx"
The Car Is Running Fine And Im Not Even Throwing A Ses Light But Still It Bothers Me That I Cant Clear These Codes From The Hpt Scanner Screen....
Does Anybody Have A Clue Whats Going On?
acctually in the rtt thread/.12 update someone from hptuners, i think chris, said that you have to wait for 10 secs after the car is running to use rtt due to the fact that modules are communicating alot at first startup, this could be your problem.........if its not your problem im subscribing to the thread and will be back in here to give you some easy tips on how to diagnose communication problems
Yeah, those are not related to RTT. We added reading DTC's from other modules. Those show up when you program the vehicle and the BCM, IPC, etc can't talk to the PCM. They were always there, you just didn't know about them until .12
We either have to add a way to clear them, an option to hide those codes or just not report them. It confuses people into thinking something is wrong with the vehicle.
-Ken
yea a way to clear them would be good...
-Ken
-Ken
Originally Posted by gameover
during the reflash most of the modules on the class2 bus list codes complaining that they couldn't talk to the PCM. This is normal.
Originally Posted by Michael55123
Yeah, a way to clear these would be awesome. Wonder if it would do away with that god damned annoying air bag light after the cluster swap?
Mike
Mike
FWIW, I had a rash of bus communications errors a while back (Uxxxx DTC's). Turned out to be the ground bolt on the back of the cylinder head had come a bit loose.
