PID's working, but AFR Error not? I finely got my LM-1 working through my egr using a custom PID, but now i cant get my AFR Error PID to work, my formula for my Wibe band is ([PID.2811]/.5)+10 and my formula for my AFR Error is 100*((([PID.2811]/.5)+10)-[SENS.121])/[SENS.121], y is my WB working but not my AFR Error? |
not familair with that format, but AFR error is commanded/actual. Assuming you are trying to dial in your VE table |
AFR Error is already defined in HP Tuners. Just create a user defined PID that takes your EGR Input and convert it to an AFR value and just assign it the sensor of AFR and now everything in the scanner works perfectly. :) This is the beauty of our sensor system. :) - Keith, HP Tuners |
| All times are GMT -5. The time now is 10:01 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
