IAT High Input?
Old Jul 24, 2006 | 09:03 PM
ws6formula98's Avatar
Default IAT High Input?
Well today after doing little burn out, About 3 mins later te check engine little turns on. So I went to Autozone and they checked the computer and it was code 113, Air intake Temp High Input. What can it be? The guy told me it could be the AIT sensor, so I got it, and put it on, buy still on.(i didnt diconnect the batter). Any ideas? thanks
Old Jul 24, 2006 | 10:26 PM
foff667's Avatar
LS1TECH Sponsor
uh did you clear the code? If not it will probablyt ake a few drive cycles to go away.
Old Jul 24, 2006 | 11:12 PM
jimmyblue's Avatar
Moderator
Maybe jerking the motor pulled on the harness and
the connector came loose.
Old Jul 24, 2006 | 11:38 PM
Camaro Bird 1987's Avatar
Try what he said, but also consider that just because a sensor throws a codes doesn't exactly mean that the sensor is bad. Was it verry hot outside when you did the burnout. The load and the high RPM could have made the underhood temps hot and throw the code. I mean it could have been a lot of things though.
