LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   lost both o2's at the same time (https://ls1tech.com/forums/pcm-diagnostics-tuning/551018-lost-both-o2s-same-time.html)
z-ya Jul 31, 2006 12:22 PM
I have a scanmaster in the car for daily knock reporting.Today I get a ses
code 0153 on the way to work and notice both o2's are very lazy.What could
cause something like this when both sides die at the same time?These are
denso sensors less than a year of use.No leaded fuel ever and nothing was done to the car prior to this happening except a gas fill up.
Tia
Mark
z-ya Jul 31, 2006 06:29 PM
Update: On the way home from work the o2's switched normally and no
ses light.Could this be some glitch in the pcm not turning on thr heaters or
somethine?Obviously the o2's won't magically heal themselves,I don't get it.
Any ideas out there please share them.
Mark
67RSCamaroVette Jul 31, 2006 11:27 PM
sometimes if the O2's do not swich quickly enough, a code will be thrown. Sometimes they can heat up and get de-fouled, going back to the normal 10 switches per second, and the code will disappear.
z-ya Aug 1, 2006 12:40 PM
They were not switching at all when this happened ,I watched the scantool readout
sit between .935 and .960 for 20 miles.I know what they look like warming up , mine
usually sit around .450 for a while then take off.I have never seen this behavior before,
funkin weird.I also watched bank2 and it was doing the same thing.
txhorns281 Aug 1, 2006 06:54 PM
try unplugging the harnesses, clean them off, apply some dielectric grease to the contacts. Also look for wire contact with the primaries, burnt/shorted wires could cause faulty O2 operation. If you have time, pull out the O2 and look at the head. If they are overly blackened they are fouled, if they look white, could be silicate deposits from a coolant burning off in the exhaust stream. Just a couple things to look at...
z-ya Aug 3, 2006 07:54 AM
Was i there about 1800 miles ago when I did heads and cam, they looked good then.
The wires are all prepared will silcone grease when assembled,wire ties used to route wires away from all hot spots also.I can't understand how it could do this and then heal itself.
© 2026 MH Sub I, LLC dba Internet Brands
