Wideband VE tuning ? When I paste my afr error % to the primary VE table what value should I use +,-,or average. I thought it was the average and then multiply by %, but I did that and after two runs the error% is still way off and the afr is still inconsistant. Any input appreciated. Thanks |
use average and muliply by % till u get close then use 1/2 % |
Clear the fuel trims and don't start logging until the car is completely warmed up. |
The ltft is disabled so would it matter if reset them? |
would not matter. but it sounds like it'd be worth a shot to double check and make sure you tune is set up correctly for SD mode. |
I am using the maf enhanced os right now and I think it is setup correctly for olsd, but if I changed the os to speed density enhanced would it guarentee that I am in olsd? |
© 2024 MH Sub I, LLC dba Internet Brands
