LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Who's running Open Loop with a MAF? (https://ls1tech.com/forums/pcm-diagnostics-tuning/572601-whos-running-open-loop-maf.html)
Patrick G Sep 8, 2006 03:34 PM
I am. After the problems with my narrow-band O2 sensors, I got my speed density tune really good with the wideband. I even leaned out the cruising cells so I'm closer to 15.0:1 A/F ratio so I can pick up a little fuel economy.
Since I've been wanting to run a dry shot again, I went ahead and rescaled my MAF and now I'm running 100% open loop, but with a MAF. Am I one of hundreds doing this or am I alone?
TAQuickness Sep 8, 2006 03:44 PM
There are a few others out there.
Sport Side Sep 8, 2006 04:04 PM
I am for the same reason (dry shot)...
rjkZ28 Sep 8, 2006 04:31 PM
i didnt get to choose, but when i brought it to speed inc to get a basic tune, they put the car on open loop w/ maf. i herd havin ur car on open loop does not make the car ever run the same again. maybe speed inc can chime in on this one. i plan on tuning my car through speed density and leaving the pcm on closed loop
GuitsBoy Sep 8, 2006 04:45 PM
Im running open loop - MAF and loving it. I feel that the MAF has improved drivability. im not worried about it being a restriction as its hogged out pretty darn good.
SmokingWS6 Sep 8, 2006 04:53 PM
I have two cars running in this method. narrowband o2's are not pratical in all situations. I nailed down the ve tables then maf. They run great with OL and maf. For awhile it seemed I was the only one doing it too.
Patrick G Sep 8, 2006 06:04 PM
I really like the advantage of having kick-ass VE tables to reference and also the ability to run a form of lean cruise. The MAF just gives me a little more flexibility and also enables me to run the sneaky dry shot. I knew I was running these big injectors for a reason, haha.
RedHardSupra Sep 8, 2006 06:25 PM
I've not dealt with MAF for a long time now, but smog time is here again and I'm trying to dial it in, and I'm having major issues--which is funny considering I invented MAF calibration process.
My main reason for staying away from it is that a VE table is just so much more descriptive: you have pressure and engine speed, two major influences. this way you know exactly the conditions that are going on in the engine. With MAF all I got is like 6000Hz--what does that mean? But at the same time, if you hit a 5000rpm/70kPa cell on SD, it's also gonna just calculated to some airflow number, still not yielding any extra information like is it in the process of accelerating or decelerating, and so on.
The good part of SD that it's easy no nail the whole range. MAF is very easy, precise and consistant under more load, but at idle and right off idle, it's very messy and unprecise, making tuning difficult. that's why probably GM decided to give us a hybrid maf/sd mode for the low rpm/light load situations.
Bink Sep 8, 2006 10:03 PM
Right now I'm Open Loop SD. But I've spent most of my time Open Loop though the MAF.
I haven't been closed loop since the early NoGo-VE tuning days. Since the july 2003 thread -> "Changed VE Table now i have a slight Hesitation!". :D
V6 Bird Sep 9, 2006 12:48 PM
you can run the dry kit without the maf as well.
GuitsBoy Sep 9, 2006 12:50 PM
How do you trigger the proper ammount of fuel? Are you using the IAT trick to add fuel / pull spark when you spray?
Black02SS Sep 9, 2006 01:15 PM
I have done countless cars OL with a MAF. It is easy to dial it in when you use the AFR BEN's just like we do on the VE table.
ZL1Killa Sep 9, 2006 01:35 PM
i was OL with a MAF to dial stuff in and I was running it that way for a while. I liked it. now i'm CL though.
slow Sep 9, 2006 02:32 PM
Just curious when did you invent the MAF calibration process?
Ryan
GuitsBoy Sep 9, 2006 03:26 PM
Ryan
He was the guy who produced the MAF calibration spreadsheet way before HPTuners or anyone else had built in functionality for it. I dont think he meant the original GM calibration process...
fast98 Sep 9, 2006 03:30 PM
if you wanted closed loop and a leaner mixture u could also adjust the o2 switchpoints. i run about 15.5:1 im still working on getting the o2s to move a lil better at idle..........
Black02SS Sep 9, 2006 04:24 PM
Ryan
:lol: The correct way IMO is to use a AFR% error. This was thought of by HumpinSS and tested by myself. I don't uses spreadsheets anymore when all is available in EFILive.
ninobrn99 Sep 9, 2006 07:56 PM
Chad, what do you do for cold and warm starts with the MAF? ive tried it, but ive had issues with it hunting and searching for idle :mad: (not trying to hijack Pat) ;)
MeentSS02 Sep 9, 2006 09:02 PM
I've never tried doing a MAF tune...I've been SD since I started tuning. It ran so well, I figured why change? I did, however, have to switch to open loop when my O2 sensors took a dump, and I haven't looked back. I love how stable it is, and I monitor the A/F ratio with my wideband full time with my XD-16 gauge. It is always right where I want it.
That being said, I now have a full custom intake setup, and the IAT sensor isn't even close to the engine anymore, so I don't have the lean restart issues I used to have. It works great for me, and the car runs strong (for what it is).
Black02SS Sep 10, 2006 05:05 AM
Honestly, I don't do anything different. Just make sure you have the proper airflow, timing and AFR. Once those three are correct, they startup everytime.
© 2026 MH Sub I, LLC dba Internet Brands
