MAF question
Old Sep 30, 2006 | 08:31 PM
WS6nJAX's Avatar
Restricted User
Default MAF question
why is it that the slp maf's are year specific (98-00 and 01-02) and others are not? could one be made to work on the other via a tune??
Old Sep 30, 2006 | 08:34 PM
TAQuickness's Avatar
SLP puts a resistor on thier MAF's in effort to compensate for the differences in MAF calibrations from year to year.
Old Oct 1, 2006 | 10:20 AM
WS6nJAX's Avatar
Restricted User
would a tuner be able to re-calibrate one to work on any year? or is this something that is best left alone?
Old Oct 1, 2006 | 11:04 AM
jimmyblue's Avatar
Moderator
The two models have slightly different resistor values,
the early years model has a lower value and fakes it
leaner while the later one tries to sorta match the stock
MAF (a better, or at least less worse bet).
For tuning you have either to embark on a voyage of
discovery (SLP providing zero info on the resulting
freq/flow curve from their "calibration") or you just
remove the resistor and use a straight-up truck
table. Of course in that case you'd be about $150
ahead, just buying the truck MAF or a Z06 and a
pigtail or adaptor. Leaving out the value of the half
piece of Fernco hose that also comes with. At least
with a stock piece you don't have to pay someone
by the hour, to dope out the hoax.
Old Oct 1, 2006 | 11:37 AM
WS6nJAX's Avatar
Restricted User
thanks JB. will both the truck and zo6 maf need the pigtail?
Old Oct 1, 2006 | 01:23 PM
jimmyblue's Avatar
Moderator
Both are 5-wire so you need to adapt them up to the
F-body separate MAF & IAT somehow. Casper's sells
an adaptor mini-harness, or you could just cut the last
foot off a junkyard truck and solder it up.
Old Oct 1, 2006 | 02:14 PM
It's not too hard to get the 85mm OEM units adapted to the 75mm vehicles. All respectable tuning suites include the tools you'll need to recalibrate the MAF table.
