LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   pcm guru's (https://ls1tech.com/forums/pcm-diagnostics-tuning/591901-pcm-gurus.html)
68shortstep Oct 14, 2006 07:25 AM
pcm guru's
is my pcm bad if im getting voltage out of the serial data line(key on)? and have resistance to ground (the key off)?
if it makes a diffrence its on a 95 buick 3.8l
GOaT Cheese Oct 21, 2006 01:03 AM
PCM supplies voltage to data line. And resistance to ground is through internal PCM buss bar. You should see 5 volts, maybe 7, not 100% sure. As for he proper resistance value, dunno.
© 2026 MH Sub I, LLC dba Internet Brands
