LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Those that have either Atapped or Tech 2'ed (https://ls1tech.com/forums/pcm-diagnostics-tuning/60832-those-have-either-atapped-tech-2ed.html)
2K2 LS1 Nov 26, 2001 02:23 PM
What are your cars reading as far as timing? I am just intrested to see. Please post your year along wiht reading.
Pro Stock John Nov 26, 2001 02:36 PM
Re: Those that have either Atapped or Tech 2'ed
28 degrees programmed into the pcm. I have used both.
Nightclaw Nov 26, 2001 02:41 PM
The last time I A-Tapped my car, I got 27° ignition advance at WOT. It's a '99 Z28, internally stock, but a few free/bolt-on mods (Whisper lid, GMS MAF, Y-Pipe, FRA...). <img src="images/icons/smile.gif" border="0">
gwj Nov 26, 2001 03:47 PM
27.5 * @ WOT with an occasional 28*.
Patrick G Nov 26, 2001 04:17 PM
24 degrees at 4000 rpms, rising to 26 degrees by 6000 rpms. Ed Wright programming (11 to 1 compression).
2K2 LS1 Nov 26, 2001 04:28 PM
Cool I was averaging 27 with my 02' but the 01 was almost always 28. Just wonderring how much differnece I could pick up with a maf translator or if it's even worth it.
Trevor @ Texas Speed & Perf. Nov 26, 2001 09:16 PM
Wow Brad, I'm surprised to see your '02 running 27 degrees of timing! Mine showed 25 stock, and with EW's programming, it will see a little more timing in the upper RPMs. Other than that, it hovers around 25.5 degrees or so.
ViceGrips Nov 27, 2001 01:23 PM
I've hit 29 with no KR in the upper RPM's with the shitty HPP3 programming and the TT. I thought that was common. Ya'll using 94 octane gas?
2K2 LS1 Nov 28, 2001 12:28 AM
[quote]Originally posted by Trevor D:
<strong>Wow Brad, I'm surprised to see your '02 running 27 degrees of timing! Mine showed 25 stock, and with EW's programming, it will see a little more timing in the upper RPMs. Other than that, it hovers around 25.5 degrees or so.</strong><hr></blockquote>
ported meter helped, along with a few other tweaks. My 01' was even higher.
<img src="images/icons/shocked.gif" border="0">
RPM WS6 Nov 28, 2001 12:53 AM
'00 ws6, stock PCM (for now <img src="images/icons/wink.gif" border="0"> ), stock MAF: 27.5 @ WOT on A-tap w/ 0 KR.
© 2026 MH Sub I, LLC dba Internet Brands
