Speed Inc & BS3 Harness for Stock Guages
so the bs3 is basically a piggyback onto the stock pcm? do i need the engine wiring harness from the ls1 motor? i do have the pcm just no harness. is the BS3 kit everything i need to get my motor up and running? or do i need the factory engine harness and the bs3 uses that?
I've got an A4 and everything but the tach and speedo work. I'm not sure if the cam connection is right but I haven't been able to check it out since the car is in Hawaii and I'm in Oklahoma. If anyone else knows of a way to get the speedo to work in the A4 please let me know. Might save me some hassels or others if I sell my car.
TT-TECH Veteran
Originally Posted by WS-6_2002
I have the crank pos hooked up and no joy. The speedo connection gets replaced with the bs3 connection in the trans.
Jeff
