Going Carbe'd
Old Jan 16, 2007 | 06:31 PM
KWIK WS6's Avatar
Question Going Carbe'd
Want to go with a carb, What is the better system out there. The car is a 01' camaro lsjuan. What is everyone using?
Old Jan 16, 2007 | 11:33 PM
LORDHELP's Avatar
i would like to know to?
Old Jan 17, 2007 | 09:30 AM
12secSS's Avatar
You can use the stock ECM for a carb setup. If you keep the TPS%, MAP, and crank/cam sensors it should work, it just won't control any injectors (obviously). It will pretty much only control the timing. It would be nice to add a wideband and log the AFR with a scanner as you tune/drive though.
Old Jan 31, 2007 | 08:09 PM
PRAY HRD's Avatar
how could you keep the tps?
Old Feb 2, 2007 | 12:58 PM
12secSS's Avatar
Second to last, p/n 377400
http://www.tciauto.com/Products/Electronics/
