LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Widebands and TD's...how many? (https://ls1tech.com/forums/pcm-diagnostics-tuning/651614-widebands-tds-how-many.html)
erikthegoalie Feb 2, 2007 08:32 AM
I saw something about this in the past here, but wanted to ask again for the sake of it...
If you have a TD system, and run a wideband, is it safer/smarter to run one for each pipe....or will one be sufficient enough.
While some may say dont waste your money on two, can't it be argued that if there is a problem with anything on the unmonitored pipe that it could be a problem?
I mean, its like only havgin 50% of your engine monitored...correct?
I know buying two is $$ and maybe a waste, BUT, better safe than sorry, right?
THANKS :drive:
brad8266 Feb 2, 2007 08:34 AM
I have one, and its fine. two is nicer though. FAST makes a dual wideband system, it expensive but nice.
Billiumss Feb 2, 2007 09:30 AM
From a tuning standpoint you can't tune each bank independant from each other with a OEM PCM.
Just get a single and put the WB 02 at around the 3 or 9 oclock position on either side close to where the header connects to the Y-Pipe or TD.
brad8266 Feb 2, 2007 09:31 AM
You could stick the wideband right in the middle of the X
erikthegoalie Feb 2, 2007 10:28 AM
Now that is an idea I did not think of....but isnt the x a little too far from the headers for accurate readings
Thanks Bill, thatll probably be what I do...
jimmyblue Feb 2, 2007 10:37 AM
One in the crossover. Widebands make / control their
own heat and too close-in is worse than further back,
you can get faults or lose accuracy if overheated.
WS6nJAX Feb 2, 2007 10:45 AM
i put mine in the x-pipe of the duals. just make sure you dont install it close to the bottom of the x as water will gather and cause problems with the bung.
brad8266 Feb 2, 2007 10:50 AM
Widebands make enough heat on their own.
erikthegoalie Feb 2, 2007 11:22 AM
ok cool thats what ill do for sure..
Thanks a lot guys!
Erik
Reject Feb 2, 2007 09:27 PM
ok to throw in another question in the mix, if you put the WB at the X, and say you have the TSP Td that cuts off farly quickly, will that be bad? i've read on their installation instructions to not leave the sensor to close to the tail pipes or else it wont give you a true reading, so would the TD's be long enough (tail pipe wise) to give you an accurate reading?
Phoenix 5.7 Feb 2, 2007 09:45 PM
u don't have to be able to monitor both banks at a time, u can only edit both together. u can have a bung in each side and sometimes switch to make sure they are both sides are workin properly.
808ws6 Feb 6, 2007 04:26 PM
Sorry for hijacking this post...
But can you run (and is it prefered) to run the engine off of the wideband input and forget about the OEM naroowband o2 sensors?
In other words, can we do away with the old o2's and let the PCM make it's trim adjustments off of the wideband?
Thanks!
Reject Feb 6, 2007 04:31 PM
you mean like this? https://ls1tech.com/forums/pcm-diagnostics-tuning/419524-heres-how-wire-lc1-work-wideband-narrowband-same-time.html
stone4779 Feb 6, 2007 07:16 PM
Couldnt you use two histograms and average them together to create one AFR Error % Table?
I have a spreadsheet I made that you can use to run two widebands, or to just average two different logs together...CLICK HERE for the spreadsheet
808ws6 Feb 7, 2007 01:36 AM
Originally Posted by reject
Hey Reject!
Thanks for the info!
© 2026 MH Sub I, LLC dba Internet Brands
