Gear vs Speed calculator (macro and non-macro)
I don't know where you exactly want this as people go all over this board for things. But here is a gear and speed calculator i don't know if there is already one up here but here are two that my dad made.
There are 2 files. The Gear_RPM_Speed is the macro version, while the other one is just an excel sheet that you can change. You can copy and paste the cells and compare two gears or other ratios. Hope this helps some people decide on gears and transmission setups, I'm pretty sure though that someone has already put something like this out there, but just in case here it is. My dad hopes yall have fun with it.
I'm posting this in the PCM section as tuning your rearend gear and seeing the speeds sometimes benefits people, as also your top speed
Originally Posted by ZL1Killa
...LOL here is the other gear calculator.. idk why Sspdmon posted again.. but here it is, his and mine, I like his better..gives more options
