Cam Tuning Questions
The other option is to have him try and fix it with the throttle cracker or throttle follower tables. If you add in a little more air through the IAC, that might help cure some of the surging. Just don't add too much or you'll get a cruise control effect.
no i agree that i need to learn to drive the cam.. but c'mon that is annoying and i know people with bigger cams that do not have this problem at all... Are you running a stock gear or 4.10???
And my bucking occurs on both the accel/decel...
fvck, come tune my heap then
so my advise is to learn how to tune ur own cause that way you cant point fingers. hope this helps some.fuerzaws6
