air fuel ratio guage
search isnt working for me! i am trying to hook up an air fuel ratio guage i need to know which wire to connect it to from the ignition. and also the o2 sensor! im lost i dont like electrical work! thanks -dave-
ok all i need to know what do do is where do i wire the A/F gauge to the o2 sensor? i know i need the sending wire. which one is it? and where shoud i splice into it at?
That's what she said...
Originally Posted by pro2low
i already bought t and it is halfway installed if i would have known i would have
I might be installing one for a friend coming up, not sure if he's getting a wideband or just a guage, so don't be suprised when I PM you.
not a problem ill figure it out tomorow after work im done for the night haha
i still need to know where to connect to the o2 at. though to anybody else that knows!
The propper signal wire should be wire B on the O2 connector if you want to splice into it from the sensor. Just look at the connector as they should be labeled in the plastic molding. See diagram below...
