will swapping MAF's affect the tune? I bought a H/C motor that made some good power, intake to oil pan and I even got the headers & Y pipe too. I also got the PCM that goes with the tuned motor however I dont have the MAF that the motor was tuned with. I bought a new style 85mm MAF with the IAT built into it. by doing this, will this throw the tune off? even a little bit??? thanks |
Yes it can. I think I posted about this in the other section. With a modded motor, you either need to tune for the new MAF or find a direct replacement for the one that was on the motor. |
Originally Posted by SSpdDmon Yes it can. I think I posted about this in the other section. With a modded motor, you either need to tune for the new MAF or find a direct replacement for the one that was on the motor. |
A different MAF sensor period will throw off the tune. Doesn't matter if its the same part number.... |
| All times are GMT -5. The time now is 08:55 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
