bogging after i turn the car off??wtf
when i turn my car off it seemes like its bogging nasty like if i put low *** octane in it?? im running 91 octane all the time...i have a 383 forged stroker and heads and cam could that be it?
Do you mean it kinda runs on a little longer (almost like it 'diesels') after you switch the ignition off? If so, I think that's corrected with the IAC Airflow Parked table. Not the default parked position...that's only used for when the learning memory banks are empty. It's a table that's based on various IAT's that says (in grams/second) where the IAC should be at key-on and key-off. If you're engine is running on a little after key-off, I would guess this table is set too high.
