Did i mess up my PCM?
Ok, so i did the window mod to make the window roll up faster and for that i had to take out my pcm, so i did and then dosconnected the wires then after that i plugged everything back in and the code po785 shows up? did i mess up my pcm cuz this has never popped up before and recently i had my transmission fluid changed any advice will help?
it seems to shift fine, doesent idle as high now it seems, not as much flow coming out the muffler, not as loud as normal, but there is a burn mark on the blue connector 2 the pcm in one of the holes
