what pin is the clutch switch on the PCM?
Old Apr 26, 2007 | 07:31 PM
WS6FirebirdTA00's Avatar
Default what pin is the clutch switch on the PCM?
2000 Trans Am
Trying to put my 2 step in, and I have nothing in pin 35 where it should be. Kinda getting frustrated right now. Any help would be great.
Old Apr 26, 2007 | 07:45 PM
ok so I found that pin 32 on the blue connector is it, but the voltage does not change on me with it in or out.
Old Apr 26, 2007 | 07:52 PM
8a8mfh's Avatar
Yea, I was going to say it's C1 (which is blue) and pin 32 is the clutch pedal anticipation wire IIRC it grounds through the VCM.
There is a C2 32.
Old Apr 26, 2007 | 07:57 PM
8a8mfh's Avatar
Heres a link to the schematic I used when I converted from an A4 to M6.
https://ls1tech.com/forums/attachmen...chmentid=62174
It is a ground because some guys just run the wire to ground and it kind of works but not correctly.
Old Apr 26, 2007 | 09:08 PM
ok thanks for the info
Old Apr 27, 2007 | 12:03 PM
you dont happen to have any diagrams for the clutch switch or anything do you?
Old Apr 27, 2007 | 03:53 PM
8a8mfh's Avatar
Yes, in a book.
I could be wrong but there might be one in the manual trans forum, the sticky about A4 to M6 swap, it's not in the auto trans forum sticky.
I may know off the top of my head, IIRC there are two switches on the top of the pedal arm and one on the floor for the neutral safety. What do you need to know?
Old Apr 27, 2007 | 03:58 PM
SSpdDmon's Avatar
I think I need to check these out too because I believe my car thinks it's always in gear.
Old Apr 27, 2007 | 08:53 PM
Technoman64's Avatar
Here is the schematic for a 2000 TA M6
File Type: pdf
Old Apr 27, 2007 | 09:27 PM
Here are a few more schematics.
There are two switches, one for crusie control and one for starting system.
Old Apr 28, 2007 | 01:38 AM
8a8mfh's Avatar
No there are three switches. Two on top for cruise control, and other things. One on the bottom for the starter, nothing else.
I have argued this before.
You want the car to start with the clutch pedal on the floor.
You want cruise to release as soon as you tap the pedal.
Old Apr 28, 2007 | 06:03 AM
I did not look under my dash, was just going by what I found in schematics.
They must use 1 for Cruise to PCM, 1 in series with Cruise Brake switch to Cruise Control Module, and the third to Starter Relay.
Old Apr 28, 2007 | 06:56 AM
There are 2 for the clutch on my car...
