Still won't connect.
Old May 9, 2007 | 06:39 PM
98RedZone's Avatar
Default Still won't connect.
I installed a cam last week, which took less time than I have put into EFIlive so far, without even getting connected. Here is what it says in my "Console".
18:28:44.312: Scanning for EFILive FlashScan V1 USB
18:28:44.328: Autodetect interface ...
18:28:44.343: Current protocol set to: "SAE J1850 VPW"
18:28:44.765: Interface firmware version: 1.2.17
18:28:44.765: Connection to [FSP] interface is OK
18:28:44.765: Autodetect PCM...
18:28:45.296: PCM not detected.
18:28:45.296: Autodetect ECM...
18:28:45.812: ECM not detected.
18:28:45.812: Autodetect TCM...
18:28:46.343: TCM not detected.
18:28:46.375: Interface firmware model: FSP
18:28:46.390: Interface firmware version: 1.2.17
18:28:46.406: Interface firmware date: Jan 18, 2005
18:28:46.421: FlashScan serial number: 003601369227
18:28:46.781: Initialising PIDs...
18:28:46.968: Initialising Modules...
18:28:46.968: Ready.
If I disconnect my usb cable, it knows that and gives a different error. If I disconnect behind the v1, I get the same message as above. My cig outlet is working, and if I pull the fuse, same message as above. So, I connect and old program called "Pro Scan". It works fine, finds and deletes codes, reads TPS, coolant temp. So if anybody out there can help me before I go insane and scrap this whole plan I would be forever grateful. If not someone will get one hell of a deal on this.
Old May 9, 2007 | 07:52 PM
kenp's Avatar
Well, I know very little about this, but I did read about EFI because I have been considering a tuner setup. It seems to me that the 98-99 is different than 00-02. So, do you have the correct software/license for your 98?
Old May 9, 2007 | 08:26 PM
98RedZone's Avatar
Yes, I select 97/98 GEN III for a 98 Z28.
