LC-1 F'd? Using EFI Live with LC-1, the sensor constantly reads 2.75v to 2.78 even in free air. Is the sensor busted? |
When was the last time you did a free air calibration? Did you double check all of your wiring? What is it programmed to report in the Innovate software? How long have you been running that sensor? |
It reads fine with Logworks. |
I had same problem digital output is fine, analog died. Just get a warranty replacement. |
Really |
Double checked the wiring. The analog 1 is set correctly. This is only about the 2nd time I've used it, free air calibrated it this morning. Is it the LC-1 I need to get replaced, or the sensor? I am gonna try using the analog 2 output and see if it works any different. |
I think I got it fixed for now, seems to be logging corectly and matches what logworks says. I'm using the analog 2 output now. Thanks 4 the help this technology is a little intimidating to me, I'm more of a gearhead than tech guy but these days u gotta be both. |
| All times are GMT -5. The time now is 09:36 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
