diablo predator problem's just wanted to know if any body had's this problem or has had this problem with there programmer. i brought it of ebay brand new and i took it to a local tuning shop so a pro could do the programming, but when he finished programming it and we tried to go back in it the programmer sat's incorrect headers found but the car was programmed with the headers on it, so now all i can do with it is take check engine codes off. if anyone knows whats going on or can help please do so thanks. :) |
Ping SprayJunkie on this forum. Mike works for Diablo and is a great resource for debugging problems. Are you sure that the unit isn't locked to someone elses VIN? If you can only reset trouble codes or use the real time monitoring function -- meaning that you can't use any of the programming functions, that's often because someone has already used the unit to program a car before selling it. |
Originally Posted by hardasskerry just wanted to know if any body had's this problem or has had this problem with there programmer. i brought it of ebay brand new and i took it to a local tuning shop so a pro could do the programming, but when he finished programming it and we tried to go back in it the programmer sat's incorrect headers found but the car was programmed with the headers on it, so now all i can do with it is take check engine codes off. if anyone knows whats going on or can help please do so thanks. :) Our tuners are here to help with these types of issues. It is not related to your headers, it is an issue with the header in the tune file. This should be easily remedied. Thanks Mike |
| All times are GMT -5. The time now is 12:31 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
