Timing/Fuel Trim help 2 Attachment(s) I've had so much trouble with my fuel trims and have finally got them looking pretty good. I'm running SD right now and just did one more scan before coming inside from work. I'm not sure on what I need to work on to get the knock down where it needs to be. Can anyone please take a look? I'd very much appreciate it! :drive: |
Anyone please? |
Originally Posted by LS1BlackBird99 I've had so much trouble with my fuel trims and have finally got them looking pretty good. I'm running SD right now and just did one more scan before coming inside from work. I'm not sure on what I need to work on to get the knock down where it needs to be. Can anyone please take a look? I'd very much appreciate it! :drive: You have some really bad KR, so you have timing problems or a bad lean condition. I would suspect lean since it is nearly 10* and you only have 6* of timing at WOT. Do you have your PE turned off? |
Originally Posted by 2000c-5 Your sig says that you have a wideband connected to your car, why aren't you using it to tune with? You have some really bad KR, so you have timing problems or a bad lean condition. I would suspect lean since it is nearly 10* and you only have 6* of timing at WOT. Do you have your PE turned off? |
© 2024 MH Sub I, LLC dba Internet Brands
