LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Installed Lt's & more need a tune? (https://ls1tech.com/forums/pcm-diagnostics-tuning/750771-installed-lts-more-need-tune.html)
Kanes2413 Jul 17, 2007 01:03 PM
just did basic bolt on's Lt's ORY catback. The car runs rough and sounds odd. I was planning on a tune but most places are busy for a few weeks and no one around seems to have the hardware. What kind of problem am i running into and what place sells stuff for tuning my 99 ls1 and how hard is it tune yourself?
ZL1Killa Jul 17, 2007 01:16 PM
your car is gonna sound way different and you are going to hear vibrations and noises that you normally don't hear. you are going to want a tune. for a 99 ls1 you can get EFI LIVE (www.efilive.com) or HPTuners (www.hptuners.com)
i use efi live it costs anywhere from 500 and up to get the software
RooRnZ28 Jul 17, 2007 01:21 PM
yes, the car will run rough and you will go thru gas faster until you get a tune. it is a night and day difference
foff667 Jul 17, 2007 01:21 PM
Mine ran perfectly fine after I threw on Headers & an ORY...ran like that for ~4 1/2 months without issue other than having the ses light blaring at me. Check to see what codes you are getting, if its running rougher than normal you might be seeing a p0300 missfire code which would lead me to think its a plug or wire issue, possibly just a loose wire, or a cracked plug.
© 2026 MH Sub I, LLC dba Internet Brands
