LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   twin MAF'S (https://ls1tech.com/forums/pcm-diagnostics-tuning/779566-twin-mafs.html)
abbaskhan Sep 7, 2007 08:31 PM
twin MAF'S
might seems like a strange question but......is it possible to run two mafs on the ls2 if so how???
00'WS6Rocket Sep 7, 2007 08:33 PM
I've never heard of that? What would be the purpose?
abbaskhan Sep 7, 2007 08:51 PM
well i see all these twin throttle body v8s running around wondering if we can do the same
1badjimmy Sep 7, 2007 08:58 PM
Why not run in speed density and omit the MAF? Or can the LS2 and LS7 not be programmed to run in speed density?
horist Sep 7, 2007 09:08 PM
I know on LS1s it's possible (Harlan runs a dual MAF for his boosted application) However, unless you're going lots of boost it's probably not worth the hastle (especially now that there are custom 2/3 bar operating systems out there)
squealingtires Sep 7, 2007 09:24 PM
I think a small integrated circuit (which type ???) would handle it. It would need to be capable of recieving 2 signal inputs and have a programmable single output. Then a MAF calibration adjustment in the PCM would polish it off. (There might be more to consider)
LS1curious Sep 7, 2007 09:49 PM
I think Harlan might have had resources that allowed him to do that.
abbaskhan Sep 7, 2007 09:59 PM
thanks guys more input would be great
im planning on twin turbos for my vette so its something id kinda like to do for the wow factor if possible
Rob Sep 10, 2007 05:39 AM
That orange Ram Air GTO(Woodward) that was made by GM had twin MAF's. They said it was a nightmare to tune.
2002_Z28_Six_Speed Sep 10, 2007 02:48 PM
Assuming there is no airflow limit, floating point OS, there is no need for twin MAFs. You could build the sender into any tube and as long as you position it ok and calibrate it to the characteristics of that intake you are good to go.
You can't just add the signals together. It would require a whole new OS and too many engineering hours.
RE AND CHERYL Sep 10, 2007 08:22 PM
An SD tune would be way easier to do.
Re'
moehorsepower Sep 11, 2007 08:20 AM
Twin MAF's
Back in 97 we tried the idea on dual MAFS on my Boosted LT1, there was no signal problem, the problem was that the MAFs were not seeing an ideal split of 50/50 on the intake air flow, one would register like 60% and the other at 40% and of course this would differ on every pull. It was just an idea at the time, I just ended up tuning with my stock maf and all was fine...
2002_Z28_Six_Speed Sep 11, 2007 02:49 PM
That is very interesting info! How did you connect them to the PCM? Any other results?
Funny how stuff works, huh?
moehorsepower Sep 13, 2007 04:23 PM
twin mafs
I really do not remember how the electronics were hooked up. I actually did not do the electrical part just the mechanical of fabricating the intake tube for the dual mafs..This was quite a while back..
© 2026 MH Sub I, LLC dba Internet Brands
