LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Stock computer's limits (https://ls1tech.com/forums/pcm-diagnostics-tuning/781711-stock-computers-limits.html)
LS1.6 Sep 12, 2007 12:48 AM
I have a LS1 that has gone from 346 c.i.d. to 383 c.i.d. and a Lunati cam that has 230 lift <----not sure about that....Stock heads with port and polished....Flowtech Headers..and stock fuel system....Can my stock computer and my stock fuel system keep up the demand of my motor or will I need a tuned computer and upgrade the fuel system....I plan on having the computer programed by FAST but I need to break in the motor...please let me know if I am just a fool in the search of happiness or am I heading in th right direction.
Frost Sep 12, 2007 01:00 AM
You will need computer tuning. This is well within the boundaries that the stock PCM can work for. You will be on the edge of things for fuel; likely will need injectors and possibly a new in-tank pump like a walbro.
Tuner@Straightline Sep 12, 2007 01:41 PM
The the custom opperating systems avaibable to the tuners today, really the only limit is how big of an injector you can control.
YellowToy/A Sep 12, 2007 03:15 PM
You will need a tune an injectors.
Tainted Sep 12, 2007 03:22 PM
the stock pcm can put up with some pretty insane hp and control a radical engine. youre very well within the limits of what it can take. however a fuel pump and bigger injectors would help out.
RE AND CHERYL Sep 13, 2007 07:34 PM
Yes the stock PCM can control it (with tunning).
No I would not drive it until you at least get a mail order tune.
You probably need bigger injectors.
R'e
© 2026 MH Sub I, LLC dba Internet Brands
