HPT won't log maf I'm having a little issue logging mass air flow. Its stuck at 2.64 g/s. Switched to another maf, same thing. Raw Hz stick at zero. WTF? |
are you logging all the proper parameters to log the MAF readings?? you can't just have 1 parameter..i believe you have to have 2 or 3 open to read the MAF sensor |
sounds like you might have a wiring problem. |
hmm.. maybe IAT related, i will have a look. You need RPM and what else? |
MAF(SAE) is all you'd need to log in your table display to be logging maf. |
You don't need anything special to log MAF Hz or g/sec, these are straight PIDs (on a standard OS anyway, dunno about the speed-density-only ones). Check the power to the MAF, ENG SEN fuse and the at-the- connector (should be a +12V and a +5Vish). |
I will check that today, thanks. There is nothing in the calibration file that I turned off by addicent is there? I look at anything airflow related that seemed relavant and I havent touched anything in there in ahwile, it all seems fine. I did add a pin to the pcm last year to log thru the EGR, but the scanner has worked fine since the re pinning untill now. I am getting a code for insufficient maf frequency hmm. I'll make sure the maf is getting power. |
definitely check the eng fuse. someone else on MM had this same problem and it was the fuse. :cool: |
Originally Posted by Checkmate definitely check the eng fuse. someone else on MM had this same problem and it was the fuse. :cool: |
Originally Posted by Checkmate definitely check the eng fuse. someone else on MM had this same problem and it was the fuse. :cool: I have run into this tuning a car as well... same thing |
The ENG SEN fuse was blown. I haven't hooked up the scanner yet but that had to be it. Thanks guys, I probably would have tore the wiring harness out or something before looking there. :) |
| All times are GMT -5. The time now is 03:13 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
