Buying injectors, which is the best way to tune?
Im buying 42lb injectors very shortly, my car is running lean and i know with my mods (listed in sig) my injectors are probably running near 100% duty cycle if not maxed out. I already have a full dyno tune from SLP. Should i go back to them to get a re-tune or should I try HP tuners. Im a little weary of plugging in another programmer since my car is already backed up by DiabloSport as well. I dont really know too much about fueling or tuning so any help would be much appreciated.
you can tune it with HPTuners if you have it, if not its not hard to do at all to adjust the car for the bigger injectors. I currently have 42# injectors and my car runs fine. I could share with you the tables and such and my excel sheet that tells you what to plug in for the values
