402 LS2 Knock Retard - or lack thereof Forgot one other question in my other thread, but figure it would be better to keep the topic separate anyways... Knock retard - I have seen ZERO on my new motor. I have also heard zero, not that I want to. My maybe flawed searching doesn't pull up much of anything recent (bigger discussions are around 2 years old). After reading about various issues here regarding an LS2 in an LS1 vehicle, will the sensors work, will they not pick up knock, etc., what do I need to do? Something I can do to make sure the sensors are working without risking damage? Although I haven't pushed it at all yet, for some reason I can't imagine that there just has never been any knock... Thanks for any input. |
Yes, the sensors are basically microphones which pickup acoustical transients. Therefore you can knock close to them with a hammer and they will detect it. Same is true with a banging header - pulls false timing. |
I saw a few degrees of knock when my car stalled a few times during the initial tune with the 416. Since then I haven't seen any knock at all, even when increasing the timing 8 degrees at WOT and running a little over 13:1 AFR. I can't hear any knock, but the car is loud even through cats and a full exhaust :) I reduced the timing after that run, since it didn't give a noticeable gain. My guess is the sensor map is completely wrong for having them in the side of the block, and they probably aren't picking up anything. |
Yea - there is something screwy with mine... I need to get under it when I get back from Hong Kong and figure it out. My guess is there is something up with the harness considering I can nail the headers with a hammer and it still doesn't pick anything up... |
Originally Posted by LankyLS-1
(Post 8366885)
Yea - there is something screwy with mine... I need to get under it when I get back from Hong Kong and figure it out. My guess is there is something up with the harness considering I can nail the headers with a hammer and it still doesn't pick anything up... In the early stuff, they resond to any metallic knocking noise, ie rod knocks, exhaust manifold leaks, loose brackets, etc. They operate differently on many later model vehicles. |
© 2024 MH Sub I, LLC dba Internet Brands
