LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Can't get rid of this code.. (https://ls1tech.com/forums/pcm-diagnostics-tuning/847583-cant-get-rid-code.html)
kukri Jan 17, 2008 08:00 PM
OBD II 0121 in a 01 LS1...MS4 cam M6 car.
This code has probably been on and off ever since the MS4 cam swap
"Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem "
There doesn't seem to be throttle problem..
Pedal position sensor..where is that? I got the swapped RX7 :confused:
Switch a circuit range (what is this :confused:)
Performance Problem - doesn't seem to be a performance problem..
Thanks
foff667 Jan 17, 2008 08:23 PM
http://www.hptuners.com/forum/showthread.php?p=101510 hope this helps.
:cheers:
kukri Jan 17, 2008 11:05 PM
Sure does, appreciate it, will try to find a tuner somewhere in town.. can't believe tuner (very well known LS1 tuner) who dynotuned it didn't change that.. hmm..or how much does one of those tuners cost that I could use myself?
© 2026 MH Sub I, LLC dba Internet Brands
