Team ZR1 EASE won't connect
Old Jul 21, 2003 | 08:47 PM
Black Blown 02's Avatar
12 Second Truck Club
Default Team ZR1 EASE won't connect
- tried changing from lm7 mode to generic mode.
- tried changing com ports(verified that it is com 1 on my laptop)
- tried starting truck
- made sure I was on st2-int
any ideas?
Old Jul 21, 2003 | 08:57 PM
Team ZR-1's Avatar
Default Re: Team ZR1 EASE won't connect
You need (MUST) to assign a printer to LPT1, even if you do not intend to use a printer, it is used for formatting of certain screens and certain fonts esp if using XP OS but a printer has to be assigned even if you pick a generic printer from MSwindows setup for printers.
Also make sure in the comm setup screen that your selecting the model number of the interface you have from Ease ( model number is written on top of interface box) if it is RS232 or USB cable and correct com port.
If you still have a problem e-mail me and I can help you along.
Old Jul 22, 2003 | 12:48 AM
Thanks I'll try that!
Old Jul 22, 2003 | 01:57 AM
I assigned a default printer, and made sure I had the right interface assigned.It's an rs232 cable in com 1 (how do I know for sure its com 1) Still no luck. My E-mails to you keep getting returned because of an address problem, could you give me the address to make sure?
